Ruland offers rigid couplings that are designed for packaging applications. They have precision honed bores, anti-vibration hardware, and opposing hardware on two-piece styles to ensure superior fit, alignment, and holding power. Rigid couplings from Ruland are available in a wide variety of sizes, styles, and materials to suit the needs of packaging applications such as case erectors, cartoners and form, fill, seal equipment.
Ruland rigid couplings are ideal for shaft-to-shaft connections and precise servo driven applications, as they do not introduce misalignment, vibration, or bearing noise into the system. Straight bore rigid couplings have precision honed bores for better fit, torque transmission, and alignment. The cross cut design accommodates slight deviations in the size of the shafts being connected for proper fit.
All Ruland clamp type rigid coupling hardware is supplied with proprietary Nypatch coating to resist vibration and maintain holding power. Nypatch provides even seating of the screw, repeated screw installations and prevents galling.
Rigid couplings are offered in one- and two-piece clamp styles with or without keyways in bore sizes ranging from 1/8 in. (3 mm) to 2 in. (50 mm). Materials are carefully selected from North American mills and include 1215 lead-free steel, 2024 lightweight aluminum for low inertia and 303 stainless steel for corrosion resistance. Custom dimensions, inch to metric step bore combinations, and 316 stainless steel are available by request. All Ruland couplings are RoHS2 and REACH compliant.
Ruland
www.ruland.com
Filed Under: Coupling Tips
