The Compact Ring Drive (CRD) system, with precision grade bearing and drive mechanism in a sealed housing, is easily programmed. The three-drive design allows the CRD to handle high speed, high torque or both, depending on the application. With a 250 or 350 mm dial plate bolt circle diameter and a large open center, users can optimize performance in a small space. The combination of roller pinion technology with integrated bearing and motor/gearhead deliver a rigid, smooth system with zero backlash options from the motor through the driven load. The CRD suits applications including cutting systems, gantry systems, medical products, robotics, aerospace, machine tool, semiconductor and material handling.
Benefits include:
- Indexing precision up to ± 30 ArcSec and repeatability up to ± 5.1 ArcSec
- Zero backlash options
- High output load capacity – up to 108kN
- Handles speeds up to 225 RPM
- Smooth in motion
Nexen Group, Inc.
www.nexengroup.com
Filed Under: Aerospace + defense, Machine tools + subtractive manufacturing, Semiconductor manufacture, Medical-device manufacture, Material handling • converting, MOTION CONTROL, MORE INDUSTRIES
