ROLEC’s new ultra-modern multiPANEL designer command and display enclosures combine technical finesse with maximum flexibility.
These highly attractive and versatile IP 65 enclosures are designed for fitting to suspension arms and can be specified for a huge range of applications involving displays, touchscreens and flush integration of PCs.
New multiPANEL is suitable for every conceivable mounting variant. It can be installed hanging, upright or on a movable suspension arm.
It is possible to glue panels or plates flush into the enclosure front or screw them in place from the inside (mounting them either flush or recessed).
Four rear options are available: flat panel with lock and external hinges; simple bolted flat panel; framed rear door with lock and internal hinges in depths of either 0.59” or 2.36”.
New multiPANEL is available in three depths – 2.75”, 3.34” or 5.11” – and in custom-specified lengths or widths up to a maximum 31.50” x 31.50”. It is manufactured from extruded aluminum with stainless steel trims.
Options include an ergonomic grab handle. Its asymmetric shape offers room for a laser-engraved logo or legends.
ROLEC has designed multiPANEL for mounting on its modern and ergonomic profiPLUS (IP 54) aluminum suspension arms.
This elegant, modular multivariable system can handle loads between 80 kg and 40 kg depending upon configuration. Simple ‘one screw adjustment’ speeds up installation times.
ROLEC profiPLUS is available in two tube diameters (1.97” and 2.76”) – both of which offer spacious routing for USB, HDMI, DVI and CP-Link 4 cables. All the junctions have integrated cable protectors.
The arms can be mounted on walls, floors or ceilings thanks to a wide choice of diecast aluminum joints and couplings. The standard color is light gray (RAL 7035) with plastic covers in anthracite gray (RAL 7016).
ROLEC multiPANEL can be fitted directly to profiPLUS 50 or to profiPLUS 70 with an optional 1.97” to 2.76” adapter.
Customization options include custom colors, CNC machining, printing, engraving, laser engraving, RFI/EMI shielding, membrane keypads and assembly
ROLEC
www.rolec-usa.com/en
Filed Under: Cabinets • enclosures • control panels, MOTION CONTROL
