The RVK gripper with a revolving head (from Schunk) allows for easy application of Collect & Place robotic tasks by giving arms the ability to collect several workpieces before transferring them.
The gripper in the working position works independently from the other grippers, which remain in the gripped state when not in use. More after the jump.
The RVK gripper with revolving head allows for lower cycle times and fewer transport strokes in a pick & place system and because of its integrated valve technology, fewer valves are required as well. It can be used in clean to slightly contaminated environments such as assembly or packaging areas, or wherever fast cycles are required.
Integrated electric feed-through allow all of the grippers to be continuously monitored leading to high process reliability. The RVK can be easily mounted to the ERS 135, 170, or the RST-D 087 from SCHUNK. It can also be adapted to mount on other rotary units, such as another rotary module or a robot arm, as long as there is a through-bore available.
Standard adapter plates allow the use of various grippers as well as the ability to externally or internally grip workpieces.
Schunk SRM universal rotary unit offers shock absorbency, high performance
The Schunk SRM universal rotary unit ensures high performance for production automation. It significantly stands out when compared to existing rotary modules on the market. Compact and cost-effective …
High-speed picker with safety functionality from Schunk
The Schunk EGP Safety is the world’s first performance level d/SIL3-certified electric small component gripper on the market with omnidirectional gripping force safety. In combination with a special…
EGN: the first certified human-robot safety gripper by Schunk
The EGN Safety is the first certified safety gripping system from Schunk for use with human and robot interaction. It is certified in accordance with DIN EN ISO …
New gripper modules from Schunk with improved lubrication
The new PGN-plus Permanent from Schunk is raising the bar. Its unique permanent lubrication provides a faster and more even distribution of the lubricant, even with short strokes….
SCHUNK SRU-mini-speed rotary unit
The SCHUNK SRU-mini-Speed rotary unit sets a benchmark in high-performance assembly in terms of cycle time and frequency. With 2 model sizes, these speed models from SCHUNK provide…
Schunk – multi-functional ERS rotary module
Schunk’s ERS rotary module that features a center hole for cable feed through as well as a compact dimension, making it ideally suited for designing orderly arranged and compact…
SCHUNK LEG 400 gripper weighs only 6.5 kg
SCHUNK (www.schunk.com) has expanded its portfolio of modular long-stroke electric grippers with the addition of the LEG 400. Equipped with a servo motor, this weight reduced gripper offers…
Two motion groups become Motion Control & Motor Association
The Motion Control Association (MCA) and SMMA (the Motor & Motion Association) have completed a merger that combines the two trade groups serving the global motion control market …
The post Schunk now sells RVK gripper with revolving head appeared first on Robotic Tips.
Filed Under: Cables + cable management, Motors • servo, Robotics • robotic grippers • end effectors
