32 new sensor mounting brackets from Wenglor have been added to AutomationDirect’s sensor accessories offering. New brackets are available for inductive, magnetic, capacitive and ultrasonic proximity sensors, along with photoelectric, laser and fiber optic sensors, and in 3, 4, 5, 6.5, 8, 12, 18 and 30mm sensor sizes.
New mounting bracket configurations include right-angle plastic brackets with and without insertion stops. A right-angle bracket with a fine-tune feature that allows vertical and horizontal adjustment for sensor placement is also available.
Swivel mount brackets are available for 8mm, 12mm, 18mm and 30mm sensors; the brackets are constructed of stainless steel or with a stainless steel mounting plate and aluminum head. The right-angle swivel brackets mount on a secure 12mm rod and provide 360 degree vertical and horizontal adjustment. Stainless steel mounting rods are available in 200, 300 and 500mm lengths.
These new sensor mounting brackets are priced from $6.00 and are backed by a one-year warranty.
www.
Filed Under: AUTOMATION, Flanges • supports • mounts • brackets
