Small PCB Terminal Block
MIDDLETOWN, PA
— The PTSM is Phoenix Contact’s newest PCB terminal block. Standing just 5 mm tall with a 2.5 mm centerline, the PTSM’s small footprint allows for numerous design possibilities.
The spring-cage connector is rated for 6 amps. It is available in two mounting technologies: pin-in-paste method or surface-mount technology (SMT). Both technologies save time and costs compared with traditional mounting methods. Rugged surface-mount device (SMD) anchors enable multiple wire termination and disengagement cycles.
The PTSM is ideal for space-critical applications such as LED lighting, building automation and power supply units.
Phoenix Contact
www.phoenixcontact.com
Speak Your Mind
