Pneumadyne introduces the new “22” Series Solenoid and Air Pilot Operated Valves in 3-Way and 4-Way configurations with 1/8 NPT (F) ports. These high flow valves provide a flow rate of 40 scfm at 125 psi and feature single or double air pilot and solenoid operators. 1 Watt, 15 mm solenoid valves consume less power and offer a variety of connector and voltage options. The 4-way valves also include a 3-Position version with either closed or exhaust centers.
Unique to the “22” Series, the Latching Solenoid operator can replace two solenoid valves in a 4-way, 2-Position “double solenoid” configuration; a space and energy saving option.
An exclusive PTFE impregnated surface on the spool results in a smooth, slippery finish extending product life and enabling the valves to be used with lubricated or non-lubricated air. Two to 10-station manifolds are available for mounting convenience.
Filed Under: Pneumatic equipment + components, Valves, FLUID POWER
