Stafford’s new line of Stackable shaft mounting collars are designed to fit at a 90° angle for rigidly mounting tubes, shafts, or other devices.
The Stafford 90° mounting system features two stainless steel shaft collars with machined flat slots on their O.D. that precisely fit into each other at a right angle.
They are suitable for applications where vibration and thermal shock are a potential problem.
Available in 3/8”, 1”, and 1-1/8” I.D. sizes made from stainless steel with stainless steel fasteners, the Stafford 90° mounting system incorporates two-piece shaft collars with smooth bores to protect shafts and evenly distribute the holding power on tubes and can be used to align sensors up and down.
Custom materials, sizes, and mounting angles are offered.
Stafford
www.staffordmfg.com
Filed Under: Coupling Tips
