The RESF37 stainless steel helical gear reducer and KESA37 stainless steel helical bevel gear reducer use less energy, run cooler and last longer than typical single-worm gear units. They resist bacteria, chemicals, and processes common to the food processing industry. The shaft-mounted gear units are available with TorqLOC, a compact keyless hollow shaft mounting system that combines interchangeable bronze bushings and a stainless steel clamping ring for mounting onto various sized solid shafts.
The reducers are available with NEMA C-face motor adapters, IEC adapters or as gearmotors. Other options include seals to provide IP69K protection and food grade oil. All shafts and hardware are high quality stainless steel as standard. They are available with ratios up to 134.82 and 106.38:1. Both have an input power rating of up to 3 hp and an output torque rating of 1,770 lb-in.
SEW-EURODRIVE
www.seweurodrive.com
Filed Under: MECHANICAL POWER TRANSMISSION, Gears • gearheads • speed reducers, Motion control • motor controls
