Precision 20° pressure angle stainless steel miter gears from Quality Transmission Components are stocked in 10 sizes in modules 1~3 in both 20 and 25 tooth. These gears, identified as the SUM Series, are made of SUS303 and conform to precision grade JIS B 1704 grade 3 standards. They are stocked in sizes ranging from Module 1 to Module 3. Bore sizes range from 6 mm to 20 mm and hub diameters from 16 mm to 65 mm.
In addition to these stainless steel miter gears, QTC stocks a wide variety of miter gears in other materials including: steel, plastic, injection molded, sintered metal, and in specialized types including: carburized & hardened, angular, finished bore, and spiral miter gear types.
At the new QTC eStore you can get immediate quotes, download 3D models, and place online orders. Go to: http://www.qtcgears.com/RFQ/default2.asp Other power transmission solutions provided by QTC include over 9,000 off-the-shelf timing belt pulleys, belts, belt and roller chain tensioners and other components for prototypes and production applications.
www.qtcgears.com/QTCPress/SSMiterGears.htm
Filed Under: Assembly, MECHANICAL POWER TRANSMISSION, Gears • gearheads • speed reducers
