Constructed of high grade 316 stainless steel, these durable fittings provide a simple push-pull method of connecting pneumatic components to each other and system piping. Push-Quick fittings allow full flow through the hose/tubing I.D. with no smaller orifice required as in barb fittings. They are designed for use with both flexible hose and stiff tubing made of nylon, polyurethane, polyethylene or polypropylene. Many styles and sizes are available.
• Offers high corrosion and chemical resistance with approval for use in packaging and food environments
• Ideal for high temperature applications
• Small, compact design
• Complete offering of hose and tubing available at www.clippard.com
Clippard
www.clippard.com
Filed Under: Pneumatic Tips
