J.W. Winco, Inc. announced it now has available GN 810 “Universal Fit” Stainless Steel Vertical Acting Toggle Clamps with Horizontal Mounting Base.
These vertical acting toggle clamps work according to the toggle principle, as the lever and clamping bar move in the same direction. In the clamped position, the operating lever is in its vertical position. The RoHS compliant vertical acting toggle clamps in the U-bar version with two flanged washers can accommodate an application specific clamping screw. A version including the spindle assembly with neoprene rubber tip is available as a standard. The “Universal Fit” base allows for both inch and metric hole pattern mounting.
All the toggle clamp’s moving parts are lubricated with a special grease. The hand grip is made from a high quality, oil resistant red plastic.
J.W. Winco offers an extensive selection of inch and metric size adjustable levers, cabinet U-handles, plastic and steel hinges and locking mechanisms, revolving and retractable handles, hand wheels, hand cranks, tube connection and conveyor components, inch and metric construction tubing, shock absorption mounts, leveling mounts, hand knobs, spring, ball and indexing plungers, jig, fixture and fastening components, retaining magnet assemblies, toggle clamps, metric casters and wheels, universal joints, oil sight glasses, and metric tools for the industrial and commercial equipment industries.
J.W. Winco
www.jwwinco.com
Filed Under: FASTENING • JOINING • locks • latches • pins
