Stainless steel motors have an exterior construction of 300 Series stainless steel housing, end bells, output shaft, and conduit box. Motors are UL/ULc certified and conform to 2007 EISA efficiency standards. All units feature Class F insulation, Class B rise at 1.15 service factor, and epoxy-encapsulated windings. Internally locked bearings eliminate unwanted axial movement. Other features include double lip shaft seals, rubber gasket seal on conduit cover, O-rings between end bells and housing, smooth exterior with no mounting feet. Stainless steel 230/460 Vac, 3 Phase, 60 Hz (50 Hz) motors are totally enclosed and are available in seven sizes ranging from 0.5 HP to 3 HP. Fan-cooled and non-ventilated models are offered.
Boston Gear
www.Bostongear.com
Filed Under: Gears • gearheads • speed reducers, Motion control • motor controls, Motors (gearmotors)
