Steel, Aluminum, or Stainless Steel Split Set Collars with Adjustable Hand Lever Available from J.W. Winco
J.W. Winco, Inc., a supplier of standard industrial machine components, announced it now has available GN 706.4 Steel, Aluminum, or Stainless Steel Split Set Collars in metric sizes with Adjustable Hand Levers for tool-less clamping.
jwwinco-set-collarsThe split set collars can safely and simply be assembled with high clamping forces via the adjustable lever without damaging the surface of the shaft the collar is being mounted on. With a shaft tolerance that should be within h11, these RoHS compliant set collars not only serve as an end stop, but they can also be used for fixing or triggering other components such as end limit switches.
Also available in stainless steel and aluminum, the steel version body is made from sintered steel with black oxide finish. The handle of the adjustable hand lever is zinc die-cast, with a black electrostatically applied powder coat finish, and the insert and screw are stainless steel.
J.W. Winco
www.jwwinco.com
Speak Your Mind
