Steel Clamp Mounts for Toggle Clamps from J.W. Winco
J.W. Winco, Inc. now offers series GN 809 Steel Clamp Mounts for Toggle Clamps. These metric sized, RoHS-compliant clamp mounts were designed for use with toggle clamps that have a solid clamping arm.
JW-Winco-Steel-Clamp-Mounts-for-Toggle-Clamps
The clamp mount can be moved along the clamping arm and be adjusted in height. Once the desired position is reached, you can secure the mount in place with the clamping screw. The clamp mount, when installed, functions to hold pressure screws, pressure dies, and similar devices. It is fabricated of zinc plated steel with a blue passivated finish and is offered in five sizes to function with a variety of toggle clamps.
J.W. Winco
www.jwwinco.com
Speak Your Mind
