Suburban Manufacturing, Inc. (SMI), providers of reusable protective sleeving, has officially released a complete line of Radiant Shield sleeving.
The sleeve was engineered for use in applications where maintaining proper fluid temperature is important, and is available in three different variations to provide optimal abrasion protection and heat containment required for the specific application.
Adding Radiant Shield to your existing hose assemblies can maximize the thermal retention gain by as much as 25 Delta T. The sleeve is currently being used in the Industrial, Mobile, Spray Foam, and Oil and Gas Industries.
gosuburban.com
The post Suburban Manufacturing releases new sleeve appeared first on Hose Assembly Tips.
Filed Under: Hose Assembly Tips
