Exar Corporation has announced theXR79103, XR79106, XR79203 and XR79206 as additions to its family of synchronous step-down power modules with input voltage up to 40V. All four single output devices with high operating efficiency and low temperature rise in a compact QFN package include easy to use, fully integrated power converters including MOSFETs, inductors and a high frequency input capacitor.
The XR79103 and XR79106 operate from a 4.5V to 22V input supply, delivering a regulated output adjustable between 0.6V to 5.5V. With 40V maximum input voltage, the XR79203 and XR79206 add the ability to convert from loosely regulated 24VDC, rectified 18VAC and 24VAC sources. The output voltage can be set from 0.6V to 13.2V. Using Exar’s patented emulated current mode constant on-time (COT) control, these power modules have the fast transient response of conventional COT control loops, while providing excellent line and load regulation performance. These modules offer a host of supervisory and protection features for proper sequencing, safe operation under abnormal operating conditions and light load operation. The combination of wide input voltage range, a thermally efficient package, tight regulation accuracy and small solution size makes these power modules well suited for applications in communications, drones and remote vehicles, industrial, after market automotive and FPGA and SOC power systems.
The XR79103 (6mm x 6mm x 4mm), XR79106 (8mm x 8mm x 4mm), XR79203 (8mm x 8mm x 4mm) and XR79206 (10mm x 10mm x 4mm) are available in RoHS compliant, green/halogen free, space-saving QFN packages. Prices start at $4.25, $5.40, $8.50 and $9.95, respectively, in quantities of 1,000. For more information, visit the power modules page.
Exar
exar.com
Filed Under: Power Electronic Tips
