Tapered roller bearings are built to thrive in demanding environments. Tapered roller bearings are designed with an outer raceway that’s tapered off like a segment of a cone. This shape prevents bearing slippage and allows the part to accept radial loads, thrust loads, and some tilting movements.
Thin Section Bearings
If bearings with a compact design and minimal weight are needed, thin section bearings might be a good solution. Thin section bearings feature a small cross section, high stiffness, and multi-load capabilities, all wrapped up into a lightweight product. These bearings are also able to accommodate shorter development times, saving businesses time without sacrificing performance.
Thrust Load
A thrust load is a type of force applied against a bearing shaft. Thrust load is applied parallel to the line of rotation, whereas a radial load is applied against the shaft itself.
Torque
Torque is the rotational force that is key in rotating applications. Bearing torque is needed in order to start rotation of one of the bearing rings. Lubrication, bearing size, and load can all affect bearing torque.
Quality Products from Bearing Experts
Whether you need tapered roller bearings or any other bearing supplies, Ritbearing can help. Our experts can find the right parts for your applications so that your operation runs smoothly. Contact us online to order the right bearings today.
Ritbearing
www.ritbearing.com
The post Tapered roller bearings from Ritbearing appeared first on Bearing Tips.
Filed Under: Bearings, Bearing Tips
