TE Connectivity expands its MINIPAK HDL power board-to-board connector family to include a new vertical receptacle to allow for right-angle configurations. The UL-recognized, blind-mateable MINIPAK HDL connector, originally introduced in 2012, provides 25 percent more current density in a more compact design than comparable products offered in the market.
The MINIPAK HDL connector consists of a right-angle plug and either a right-angle or vertical receptacle that utilizes an eye-of-the-needle tail for use in both solder and press-fit applications. The product is fully qualified to end-of-life conditions and offers a current rating of up to 40 Amps per contact, with nine adjacent contacts in a one-inch PCB space, all carrying 17.5 Amps while remaining within the 30° temperature rise requirement.
In addition, the MINIPAK HDL product matches the performance and scalability of the previous de-facto standard Multi-Beam XL product and is approximately 35 percent less in height — resulting in improved cooling efficiencies for compact 1U power supply designs.
The connector, which is manufactured on a mass-customizable platform, allows customers to select a wide array of configurations containing up to 24 power contacts and 40 signal contacts without up-front tooling charges. The connector also contains three levels of mating sequences to suit hot-swap applications — specifically modular hot-swappable power distribution systems. Product applications include 1U servers, high-end servers and telecommunications switches.
TE Connectivity
http://www.te.com/products/minipakHDLgo
