TECHSPEC® BBAR Coated Hypotenuse Right Angle Prisms feature tight angular tolerances
Edmund Optics® introduces its new TECHSPEC® BBAR Coated Hypotenuse Right Angle Prisms. These broadband anti-reflection (BBAR) prisms feature a wide wavelength range from 350 – 2200nm and are ideal for applications that require a single axis retroreflector and optical systems with space limitations.
TECHSPEC® BBAR Coated Hypotenuse Right Angle Prisms provide a tight angle tolerance of ±15 arcsec, reducing ray deviation and eliminating the need for recalibrations of other parts of the optical system. The prisms are manufactured using an N-BK7 substrate and feature a high precision 40-20 surface quality, λ/8 surface flatness, and +0/-0.1mm dimensional tolerance.
Coating options for the TECHSPEC® BBAR Coated Hypotenuse Right Angle Prisms include VIS and NIR coatings, which reduce surface reflections in their designated wavelength ranges for increased total transmission. Eight standard VIS 0 and NIR 1 coated prisms are available with hypotenuse lengths of 14.1mm to 70.7mm and legs from 10mm to 50mm. Custom sizes are also available. TECHSPEC® BBAR Coated Hypotenuse Right Angle Prisms are in-stock and available for immediate delivery.
Edmund Optics
Speak Your Mind
