The Sensor Connection a division of Harold G. Schaevitz Industries LLC, has expanded its line of measurement and control instrumentation with the addition of the model TCA-MS-K-1. This Single Channel Type K Thermocouple Amplifier Module converts the low output voltage signal from a Type K thermocouple probe to a single independent linearized 0 to 5 VDC output voltage. This output is ideal for interfacing to instrumentation equipment including data loggers, temperature indicators, chart recorders, and controllers.
• Input: Type K Thermocouple
• Temperature Measuring Range: 0 to +1250°C
• Analog Output: 0 to 5 VDC
• Supply Voltage: 10 to 32 VDC
• On-board CJC
• Response Time: 1 mS
• Housing is rated IP 51
• Compact Size, only 2.5 x 2.5 x 0.9-in.
• Includes mini-plug signal input connector
• Includes 1m long integral signal cable
• Made in the USA
The Sensor Connection a division of Harold G. Schaevitz Industries LLC is an American company whose management has a combined experience of over 50 years in the sensor industry. We have a technically trained staff to help you select the ideal sensors for your application. Our core product offering includes Exhaust Gas Thermocouples (EGT) Probes, Thermocouples, RTDs, Linear Position sensors, Rotary Position sensors, Pressure sensors and switches. In addition to our standard products, we have capabilities to design and build custom products to suit your specific application. Major markets served include Motorsports, Marine, Heavy Vehicle, R&D Test labs, Power Generation, Military, and Industrial Manufacturing Assembly & Test.
www.thesensorconnection.com
Filed Under: Sensors (pressure), Sensor Tips
