Connecting 80 inputs to a microcontroller – I want to check inputs from optocouplers. How can I multiplex the inputs to a microcontroller? I prefer to use the8051, PIC16f877a, or ATMega. Read more.
MCP3428 interfacing – I am using the MCP3428 diferential ADC with a single shot conversion and interface through I2C to my microcontroller. It’s working fine but after 10 or 12 continuous hours, the IC is not giving any values. When I remove power and reconnect it starts working. Why is this happening and how can I solve this problem? Read more.
Learning to program microcontrollers – I want to start programming microcontrollers and am thinking of starting with Microchip’s PICs or the ATMega. I can borrow a PIC DEM FS USB PIC18F4550 board but should I start with something else? What is your advice to someone starting on microcontrollers? Read more.
Choosing a suitable PIC microcontroller for a solar charger – I’m planning to build a PWM solar charger for home use with flexibility and scalability in mind. I expect to incorporate the solar charger with the following features:
1. Based on PWM algorithm
2. Charging multiple 12V sealed lead acid batteries
3. 20×4 character LCD display for displaying voltages,current,power etc
4. Over voltage / Under voltage / Lightning protection
5. Reverse power flow protection
6. Short Circuit and Over load protection
After much research, I have decided to go with Microchip’s XLP microcontrollers. These are the options I have but I need to know if these chips adequate or are better options available? Read more.
Why is the SPI LCD not working? – I am using a Microchip 8-bit SPI Port expander. The SPI debugger shows that data is being sent properly. I am testing it in both Proteus and hardware and it is not working in either. I am using a Slaeae logic analyzer for testing in hardware and a EasyPIC v7 development board. Below is my PRO PIC project and Proteus file. Read more.
The post This week’s top microcontroller threads on EDABoard.com appeared first on Micro Controller Tips.
Filed Under: Microcontroller Tips
