Trelleborg Sealing Solutions will highlight its “Trelleborg Solution” of advanced delivery services and customized packaging as well as an array of products at IFPE 2014, booth #81929 in South Hall 3.
With a focus on increasing the total value of ownership for customers and supplying the highest quality of products and services, the “Trelleborg Solution” from Trelleborg Sealing Solutions helps accelerate customers’ business processes and delivers seal application and design for more efficient manufacturing. When coupled with its advanced delivery services, Trelleborg Sealing Solutions can help empower fluid power component manufacturers through vendor-managed inventory and supply chain solutions, such as value-added packaging and handling services. These give customers the ability to customize packaging and labeling for a more simplified stocking and handling operation.
In addition to demonstrating its service approach, Trelleborg Sealing Solutions will also show several products at their booth including:
Turcon Glyd RingII is a double-acting rod or bore, bi-directional seal for reciprocating and static applications offering lowered friction and yielding a longer service life.
Zurcon Glyd Ring D seal is produced from a Zurcon material and engineered to extend seal life in high-pressure hydraulic sealing applications. It is well suited for machines, equipment and motors filled with hydraulic cylinders.
Rotary Seals from extend product life while improving safety and performance in extreme environments in power transmission and motion control applications. Featured rotary seals are as follows:
-CSL1500 is a radically new cassette seal design for agricultural and construction equipment that maximizes performance. These seals have been proven in lab and field to outlast conventional cassette seals.
-Our new line of standard Inch Size Radial Oil Seals is made to meet advanced design standards. These seals offer sizes and styles that are available to fit a full range of applications.
Heavy duty Mechanical Face Seals are designed for severely contaminated environments. They are available in cast iron or bearing steel to give the best performance in every application.
Trelleborg
