CARLO GAVAZZI is proud to announce the launch of their new two pole solid state relays, the RK Series. Reducing the size of components is becoming a necessity for equipment manufacturers who want to stay competitive. Carlo Gavazzi has developed the RK Series with this idea in mind, as it provides solutions that minimize space requirements without compromising performance.
The RK Series consists of solid state relay (SSR) solutions which have two poles in a single housing. It gives the option of having the two poles controlled independently or simultaneously. The latter offers a cost effective solution for economy switching of 3-phase loads. The RK Series SSRs are ideal for reliable switching of resistive loads. This new series extends the current ratings of two pole solid state relays to 75 AAC per pole with a proper heat sink and provides output screw terminals for secure connectivity of cables with ferrules, ring or fork terminals.
The RK Series comes with features that provide time-saving installation and a reduction in downtime, thanks to trouble-free solid state operation, during the lifetime of the SSR. It conforms to global standards such as UL 508, CSA C22.2 and EN 60947-4-3; therefore, it can be used globally in applications/markets involving switching of resistive heating elements, i.e. Food and Beverage, Plastic and Rubber, Semiconductor, HVAC, and others.
The RK Series features include:
- Two pole switching, up to 75A per pole
- 600VAC output voltage rating
- 4-32VDC control
- Options for common or independent output control
- Plug or connector control terminal
- Pre-attached thermal pad
- UL recognized, CSA and VDE approved and CE marked
- UL 100,000 cycle endurance test according to UL508
Carlo Gavazzi
www.GavazziOnline.com
Filed Under: MOTION CONTROL, Relays
