The ultra-miniature Beswick M3 threaded dry-break quick disconnect is precisely manufactured from corrosion resistant stainless steel and is rated to 500 psig when connected. Buna-N is the standard seal material. Viton and EPDM are optional and can handle many types of fluids. Other elastomers are available upon request.
The dry-break, also referred to as “no-spill” (however there are some slight differences), configuration is a more sophisticated version of a standard double shut-off quick disconnect. The advanced dry-break design ensures that there is essentially no leakage during connection or disconnection. It also minimizes the dead volume between the internal and external ends.
Larger models in dry-break, double shut-off, single shut-off and no shut-off styles are offered.
Beswick
beswick.com
The post Ultra-miniature threaded dry-break quick disconnect minimizes dead volume between internal and external ends appeared first on Hose Assembly Tips.
Filed Under: Hose Assembly Tips
