UMF 250 Quick-Acting SMD Fuse from Schurter
Schurter expanded its line of surface-mount fuses with the introduction of the Universal Modular Fuse, UMF 250. Its quick-acting characteristic according to IEC 60127-4 complements the successful UMT series, in providing overcurrent and short circuit protection for electronic systems in primary and secondary circuits.
Current ratings up to 10 A at 250 VAC/125 VDC, the UMF 250 has a breaking capacity of up to 200 A at rated voltage. The UMF 250 provides maximum circuit protection while its extremely compact size saves PCB space over larger cartridge style fuses and facilitates assembly with pick and place mounting. The UMF 250 is ideal in applications such as power supplies, medical equipment, and devices for home and industrial use. The UMF 250 is RoHS compliant and carries cURus and VDE approvals.
Schurter-UMF-250-Quick-Acting-SMD-Fuse
Schurter Inc.
www.schurterinc.com/new_fuses
Speak Your Mind
