Unmanaged Etherenet switch for edge-level applications
The LNP-1002G-10G-SFP-24 is industrial-grade equipment that is Ethernet ready for edge-level networking applications in harsh and outdoor environments. This device supports high-density Ethernet port connectivity, 10G fiber backbone, long-distance data transmission, and has a superb reliability factor.
It offers high-density for eight full gigabit Ethernet ports with PSE: 30W per port and two 10G SFP+ fiber slots for long-distance connectivity.
This product series has an IP30 rated metal casing design that has DIN-Rail or wall mounting support. The device provides a dual redundant power input range of 24 to 55 Vdc with an overload current and reverse polarity prevention, as well as high EFT (2,000 Vdc) surge protection and ESD (6,000 Vdc) protection. Additionally, there is a built-in relay warning function to alert maintainers when power failures occur. Each unit is built to withstand industrial networking hazards like shock, drop, vibration, electromagnetic interference (EMI), and temperature extremes (-40° ~ 60°C). The units conform to the following dimensions of 54mm (W) x 99mm (D) x 142mm (H) and a unit weight of 3.0 lb.
Antaira Technologies
www.antaira.com
Speak Your Mind
