At the last Triton Users Group, Second Wind’s founding partner Ken Cohn led a panel with participation from customers who worked with us in two of the recent joint research projects: Lucille Olszewski, director of meteorology at Edison Mission Group, and Hal Romanowitz, president, and Roby Maxwell, resource assessment engineer at Oak Creek Energy Systems.
How Complex Terrain Affects Triton Measurements
The mathematics used for calculating windspeed and direction in the Triton sodar (and commercial lidar devices) assumes that wind flows across the device in a straight line. Because of the potential for curved wind flow, this may not be true in complex terrain. As shown in the illustration above, the flow angles may be different as they cross Triton’s three beams. The typical flow curvature causes a low wind-speed bias ranging from 2% to 8%.
The goal of the research was to evaluate whether CFD software, in this case Metodyn, used to model wind flow, could be used to predict the low bias. We would then calculate an adjusent factor for more accurate data. The researchers completed two sets of measurement and adjusents and compared the results. For each site, they:
- Measured the wind with a Triton for several months
- Input topographical and other characteristics to create a CFD model for the flow over the site
- Calculated a complex terrain compensation factor, called the CT factor, to adjust the Triton data.
