Piab offers its patented COAX technology in a new small sized ejector called piPUMP MICRO. COAX is the most energy efficient ejector technology based on a multi-stage concept for creating vacuum with compressed air.
The piPUMP can be used for small centralized systems but is perhaps even more suitable for semi-decentralized systems, i.e., a few units creating vacuum supporting a few small cups each. Thanks to very low weight and small size it can also be used as a fully decentralized ejector on a Delta robot.
The small footprint of the unit provides flexibility in mounting and use. Installation is a breeze with push-in connections and a common feed for compressed air, regardless of the number of units chosen. The central exhaust allows the exhaust to be drawn away in clean room environments.
The piPUMP MICRO is able to provide high performance even at low or fluctuating feed pressures (14-87 psi). Additionally, piPUMP MICRO vacuum units begin producing vacuum immediately when the pressure valve is turned on, making maximum use of the compressed air and consuming significantly less energy than traditional vacuum pumps.
Piab
Filed Under: Pumps, Pneumatic Tips
