WAGO Corporation’s 750-675 4-Channel IO-Link Master module simplifies integration, configuration and management of intelligent sensors and actuators. Utilizing the IO-Link Standard jointly developed by prominent industrial suppliers, WAGO 750-675 eliminates time-consuming configuration of field devices via proprietary handheld units. The module also reduces device wiring to three conductors, minimizing automation footprint, engineering, commissioning and maintenance costs.
Get to the Point: The 12mm-wide 750-675 integrates IO-Link below the control level for point-to-point linking of field devices to the WAGO-I/O-SYSTEM. The module provides centralized network-based configuration for devices from multiple vendors via WAGO-I/O-CHECK configuration software and WAGO-I/O-SYSTEM coupler or controller. The network-independent 750-675 functions as a gateway from I/O-Link to any major fieldbus for interoperability.
Network-based configuration replaces proprietary handheld configuration units and requisite training to streamline machine-building and control applications for industries such as packaging, food/beverage and pharmaceutical. 750-675 also economizes device maintenance, minimizing service for difficult-to-access applications, e.g., roof-mounted level control devices atop silos. The I/O-Link Module bolsters application reliability via vibration-proof and maintenance-free CAGE CLAMP® Spring Pressure Connection Technology. Approvals: CE Conformity, UL/cUL (UL 508) and Electromagnetic Immunity (EN 61000-6-2).
WAGO
www.wago.us
Filed Under: Actuators, I/O modules, CONNECTIVITY • fieldbuses • networks, SENSORS, Motion control • motor controls
