In many applications, the decision to select a standard bearing yields an effective solution.
But there are other instances in which an OEM will actually be short-changed through the selection of a standard bearing. Standard bearings often exceed the functional needs required by an application. The resulting “over-specification” creates unnecessary complexity, size issues, design constraints, and cost increases.
This webinar provides insight into the process by which a product designer can compare a standard bearing to a custom bearing, dispel the myth that custom bearings are always cost-prohibitive, and provide proven strategies that can create value throughout the production process from design to assembly to supply chain management. Product designers that are concerned with product functionality and cost control will benefit from this webinar. The webinar is applicable to a range of industries and will provide actionable insights with measurable outcomes.
Attend this Webinar to Learn:
- How selecting a standard bearing may inadvertently increase costs
- How to consider and compare a standard bearing vs. a custom bearing to achieve the most cost effective solution
- Ways in which a custom bearing can reduce costs and streamline production from design to fulfillment
- Design innovation possibilities that can only be achieved with a custom bearing
Brought to you by:
Filed Under: WEBINARS
