TDK Corporation announces the introduction of the 250W rated TDK-Lambda i6A series of non-isolated DC-DC converters. Capable of operating from an input voltage of 9V to 40V, the step-down converter delivers an output voltage that can be adjustable from 3.3V to 24V and output currents of up to 14A. The series is designed to be used in a wide range of applications including medical, communications, industrial and test and measurement equipment.
In a 1/16th brick form factor, measuring 33 x 22.9 x 12.7mm, the converters can be used in conjunction with a single output 12V or 24V AC-DC power supply to generate additional regulated high current outputs, with or without battery back-up.
With efficiencies of up to 98%, power losses are minimized allowing the products to operate in harsh ambient temperatures of -40oC to +125oC even with low airflow requirements. The need for external output capacitance is reduced due to an optimized dynamic voltage response, thus reducing board space requirements.
The basic feature models include an output voltage adjustment pin, positive or negative logic remote on-off, remote sense, input under-voltage, over-current and thermal protection. Full feature models are equipped with a power good signal, output voltage sequencing and the ability to synchronize the operating frequency to minimize system noise. All models are certified to UL/CSA 60950-1, IEC/EN 60950-1 and carry the CE mark for the Low Voltage and RoHS2 Directives.
Major applications
Medical, communications, industrial and test and measurement equipment
Main features and benefits
• High efficiency (Up to 98%)
• 9 to 40VDC input, 3.3 to 24V output adjustment
• Up to 250W or 14A output
• Basic and full featured versions
TDK Corporation
www.tdk-lambda.com
Filed Under: Power supplies, Power Electronic Tips
