Atmel® Corporation (NASDAQ: ATML) expanded its SmartConnect wireless portfolio with a wireless combo system-on-chip (SoC) for the rapidly growing Internet of Things (IoT) market. The new fully integrated WILC3000 wireless link controller combines Wi-Fi 802.11n and Bluetooth Smart-ready technologies in an ultra-small 4.1mm x 4.1mm Wafer Level Chip Scale Package (WLCSP) with lower power consumption, along with Atmel’s patented adaptive co-existence engine, making it the ideal solution for IoT and wearable applications. Atmel’s WILC3000 Wi-Fi solution offers multiple peripheral interfaces including UART, SPI, I2C, and SDIO, along with the associated cloud-ready connectivity software, making it the perfect wireless connectivity companion to any microprocessor (MPU) running Android or Linux MPUs.
Atmel is also introducing the WINC3400 network controller featuring embedded flash memory which allows the device to host network services stack, Wi-Fi stack, and Bluetooth Smart profiles for rapid design development with no wireless expertise required from the designer. The WINC3400 can be paired with any Atmel AVR® or Atmel | SMART MCUs.
“IoT requires a diverse portfolio of wireless MPUs and MCUs with Bluetooth and Wi-Fi capabilities that will enable cloud access,” said Kaivan Karimi, Vice President and General Manager of Wireless MCUs, Atmel Corporation. “Adding cloud connectivity to devices in the industrial, medical, wearable, fitness and other consumer markets will require a combination of embedded Wi-Fi with Bluetooth optimized for low battery consumption, and support for out-of-the-box, cloud ready software. Atmel’s SmartConnect WILC3000 and WINC3400 address these requirements by delivering a compact cloud-ready Wi-Fi/Bluetooth-certified platform that helps bring customer products faster to market.”
Atmel’s new Wi-Fi/Bluetooth combo solutions are optimized for low-power applications, supporting single-stream 802.11n mode providing up to 72 Mbps throughput allowing a broad range of use cases. Both products integrate a power amplifier, LNA, switch and power management unit providing developers with the highest level of integration together with the best link budget for maximum range.
The WILC3000 and WINC3400 provide the highest integration for a lower bill of material. The only external clock sources required is a high-speed crystal or oscillator with a wide range of reference clock frequencies supported (14-40 MHz) and a 32.768 kHz clock for sleep operation.
The WINC 3400 network controller offers an On-Chip Network Stack to minimize host CPU requirements. The Network features include TCP, UDP, DHCP, ARP, HTTP, SSL, and DNS. Additionally, the WINC3400 SiP includes Bluetooth Smart profiles allowing connection to advanced low energy application such as smart energy, consumer wellness, home automation, security, proximity detection, entertainment, sports and fitness and automotive. This solution also supports Atmel’s cloud-ready software for simple cloud connectivity.
Availability and Evaluation Kits
Atmel’s WILC3000 chip is available in QFN and WLCSP packages immediately. A fully certified module of this chip will be available in April 2015. The WINC3400 SiP and a fully certified module will be available April 2015.
To help accelerate design development, Atmel offers a WINC3400 integrated module on an Xplained Starter Kit platform which will be available in April 2015.
Atmel
www.atmel.com
The post Wireless link controller for IoT and wearables appeared first on FPGA Tips.
Filed Under: FPGA Tips
