A Single and Double Disc coupling size has been added to the Zero-Max ServoClass® coupling line. The addition of the SD025R and SC025R models handle 5 to 14 mm bore diameters and torque up to 4 Nm. The new size gives designers even more options when planning their systems.
Providing high torsional stiffness, these model ServoClass couplings are designed to handle high speed reversing loads and precise positioning requirements in today’s demanding servomotor applications at speeds up to 10,000 rpm.
Manufactured of RoHS compliant materials, these ServoClass couplings are lightweight and are designed with 304 stainless steel disc packs and aluminum clamp style hubs and center members. To ensure precise alignment of the assembled components, ISO 4762 CL12.9 corrosion resistant socket head cap screws are utilized with a carefully controlled assembly process.
A total of twelve sizes of standard off-the-shelf ServoClass couplings are now available in both inch and metric bores. These couplings are ideal for applications including automation, packaging, semi-conductor assembly, laboratory automation, medical equipment and virtually any product that uses ball screws and servomotors.
ZERO-MAX
www.zero-max.com
