0.6mm High-Speed CHAMP Docking Series Connector from TE Connectivity
By Design World Staff | August 26, 2011
TE Connectivity (TE), formerly Tyco Electronics, has introduced a 0.6mm CL (centerline) high-speed CHAMP docking series connector.
TE-Connectivity-0-6mm-CL-High-Speed-CHAMP-Docking-Series
The docking series connector is designed for high-density, low-profile (3.8mm) shield applications featuring two rows of contacts on a 0.6mm pitch centerline. Contacts on a 0.6mm centerline can save 30% linear board space and the 3.8mm low-profile housing reduces connector height by approximately 25%. Multiple options are available including right-angle receptacles, right-angle offset receptacles and vertical plugs for both dock and cable applications.
TE’s 0.6mm CL high-speed CHAMP docking series connector is designed to meet various industry transmission standards including USB 3.0, HDMI 1.4 and DisplayPort 1.2.
The product can be applied in the PC (laptops and tablets) and mobile devices industries.
TE Connectivity
http://www.te.com/products/pcdocking-pr
