1 mm Pitch Timing Belts from SDP
By Dave Miyares | August 27, 2010
New Hyde Park, NY — Stock Drive Products (ISO 9001:2000 Registered Manufacturer) announces a new series of 1 mm pitch polyurethane timing belts, designed for miniature applications and to run with the new 1 mm pitch timing belt pulleys. Offered with Kevlar® cord reinforcement, the A6B18M…Series are stocked in 22 different groove sizes ranging from 94 mm to 559 mm (3.701” to 22.008”) while the A6G18M…Series with fiberglass cord reinforcement are stocked in pitch lengths from 142 mm to 705 mm (5.591” to 27.756”). These unique belts come standard in 3 mm and 6 mm widths; however, special widths can be cut from sleeves, also available in stock.
SDP-1mm-Pitch-Belts
The Kevlar® belts (double span) have a breaking point of 300 N per 1 mm (214 lbf. per 1/8 in.) and the fiberglass belts, also double span, have a breaking point of 165 N per 1 mm (117 lbf. per 1/8 in.). Both have a temperature range of -30°C to +85°C (-22°F to +185°F). Since these timing belts are the smallest standardized pitch timing belts available they are ideal for important prototype or production applications that require high-quality, miniature parts. View additional specifications for the new 1 mm pitch timing belts and their compatible A6A18M…Series miniature belt pulleys easily online.
Quotes, online orders, available stock, and 3-D CAD Model downloads are available on our updated eStore at: www.sdp-si.com/eStore. SDP/SI offers over 100,000 power transmission components including: gears, belt and chain drives, shafts, shaft accessories, bearings, couplings, universal joints, vibration mounts, miscellaneous components, hardware, gearheads and speed reducers, right angle drives, brakes and clutches, motors and gearmotors.
www.sdp-si.com
Filed Under: Factory automation, Automation components, Belts + chains
Comments
  1. Christian Roth says
    August 21, 2019 at 8:02 am
    Hi
    I’m looking for an ultrasoft, thin timing belt with pitch 1 mm of smaller. The belt length does not matter at this stage.
    The application is for a clock, so the force on the belt is minimal.
    Please let me know what’s in your range.
    Best regards
    Christian Roth
Solid-state relay characteristics and applications
