AvaLAN Wireless Systems, Inc., providers of outdoor long range industrial wireless Ethernet products, announced this week a set of 5.8 GHz long range wireless Ethernet solutions. This product line allows you to build line-of-sight, point-to-multipoint or multipoint-to-multipoint (mesh) wireless Ethernet connections that link “fringe” IP devices such as video surveillance cameras or other devices needing robust and secure high data rates. The radios are packaged in rugged and weatherproof die cast aluminum enclosures and are available in both directional and omnidirectional antenna configurations. Utilizing custom AvaLAN Wireless firmware and multiple-in-multiple-out (MIMO) technology, AvaLAN’s AW58100 series delivers RF data rates up to 100Mbps. The subscriber unit directional flat panel antenna is a special dual-polarized version designed specifically for multiple spacial streams. The omnidirectional access-point and mesh units provide two outdoor industrial 6 dBi gain antennas. The dual-polarized flat panel antenna radios are also available as a pre-configured matched pair bridge (AW58100HTP-PAIR) for point-to-point fixed connections. These long range 5.8 GHz wireless Ethernet solutions are designed for applications that require higher RF data rates up to 100 Mbps and are ideally positioned to support IP-based megapixel surveillance cameras.
“AvaLAN continues to deliver compelling products to address the growing needs of our customers. Our mesh technology adds redundancy and distance capability. This line of high speed, industrial wireless Ethernet products has been specifically designed to meet the needs of security integrators and dealers who need a higher speed wireless solution for IP surveillance video.” said Matt Nelson, CEO and President of AvaLAN Wireless.
www.avalanwireless.com
Filed Under: Wireless • 5G and more, Wireless devices, Vision • machine vision • cameras + lenses • frame grabbers • optical filters • scanners
