11Mpixel CMOS image sensor for high-speed applications
By Leslie Langnau | October 17, 2018
Teledyne e2v, a Teledyne Technologies company and global innovator of imaging solutions, announces the expansion of its Lince family of image sensors with a new 11Megapixel detector. Lince11M is a new CMOS image sensor designed for applications that require 4K resolution at very high shutter speed. This standard sensor uniquely combines 4K resolution at 710 fps in APS-C format.
Lince11M can be advantageously used for in-line inspection to increase manufacturing throughput, or with strobed lighting for multispectral imaging or multi field (bright field, dark field, backlight) imaging, and serve as an alternative to line scan sensors to improve defect classification where uniform image sharpness across all directions is critical.
Lince11M takes advantage of the APS-C format and is compatible with standard optics. Its 4K resolution allows users to reduce the number of cameras, helping to lower the total cost of ownership. The 11M serves as the higher resolution member to the Lince family of high-speed CMOS image sensors offering resolutions of 1.3MP, 5MP and 6MP.
Key features:
Global shutter CMOS pixel (6μm x 6μm)
APS-C optical format in 4K resolution
700fps in 4K resolution, 1400fps in full HD resolution
Large Full Well Capacity to maximize SNR in shot noise limited application
High peak Quantum efficiency of 60% QE
Samples available in March 2019.
Teledyne Imaging
www.e2v.com
Filed Under: MOTION CONTROL, SENSORS
Tagged With: teledyne
