12- and 17-position Field-Wired M12 Connectors
By Patrick Curran | June 23, 2010
MIDDLETOWN, PA – To meet the needs of increasingly smaller machines and devices, Phoenix Contact introduces field-wired M12 connectors in 12 and 17 positions. The high-density M12 connectors can be used in applications where previously only M23 and larger connectors could be used.
Phoenix-Contact-M12_17pole-connectors
The sensor/actuator connectors use Piercecon® connection technology for easy field installation. With Piercecon, technicians can make signal connections in three steps – strip the cable jacket, insert the wires and screw the housing tight. No soldering or wire preparation is necessary.
The connectors are designed for I/O connections in applications such as image processing systems, decoders, encoders, pressure sensors, measurement devices and master cables for sensor boxes.
The M12 connectors feature color-coded terminals and are available in both male and female versions. They meet IP65/67 requirements and fit wire range #28-26 AWG.
Phoenix Contact
www.phoenixcontact.com/usa_home.htm
Filed Under: Connectors (electrical) • crimp technologies, Electronics • electrical
molex-premo-flex
