The FPS1000 12 V output front-end power supplies are for driving non-isolated, point-of-load, dc-dc converters in distributed power systems. They eliminate intermediate bus converters. Output is adjustable from 10.5 to 13.2 V. The new 864-watt model FPS1000-12 complements Lambda’s existing line of 24, 32, and 48 V output models.
The supplies each measure 1.61 x 5 x 11.4 in. Use them individually, or mount up to three in an optional 1U-high 19 in. rack-mount enclosure to form an N+1 redundant and hot-swap power system. The units have integrated OR-ing MOSFET switches that automatically disconnect faulty supplies from the load should a failure occur.
Different output voltages are available for rack-mounted supplies (e. g., 12, 24, 32, or 48 V). Up to eight supplies can be combined in a current-sharing arrangement between these racks. Racks can be zero stacked flat because cooling airflow is integrated into each supply from front to rear. Operating temperatures are from 0 degrees C to 70 degrees C, with some derating starting at 50 degrees C. Applications include communications, factory automation, and RF power amplifiers.
For compliance and safety specifications, please visit the Lambda Americas Website.
Web: www.lambdapower.com
Tel: 800-LAMBDA-4 (toll free) or 619-574-4400
About Lambda
Lambda Americas is a unit of TDK Corporation and has been a leading global provider of power solutions for more than 50 years. The company designs and manufactures a wide range of ac-dc and dc-dc power products for industrial, medical, telecommunications, data communications, and test & measurement applications worldwide.
:: Design World ::
Filed Under: Factory automation, Power supplies
