150-W High-Intensity LED Lights Replace 400-W Metal Halide units
By Editor Design World | December 3, 2015
larsonpr-151203Larson Electronics continues its commitment to providing high grade lighting equipment to specialty markets with the release of a high intensity 150 watt LED light fixture that is a direct replacement for 400 watt metal halide fixtures.
The GAU-LTL-150W-LED light fixture from Larson Electronics produces 19,500 lumens of high intensity light while drawing only 150 watts from a 120 volt electrical system. This high mast LED flood light offers intense light output and is ideal for flood lighting, high mast lighting, light towers, as well as industrial and outdoor lighting applications. Sixteen Bridgelux high output LEDs producing 963 lumens each are arranged in rows and paired with PMMA high purity optics to produce a well-focused 25° wide spot beam that is ideal for providing far reaching concentrated illumination while still covering a substantial amount of area. This fixture is also available in an optional 10° spot, 40° narrow flood, 60° flood, and 90° wide flood beam spreads. The spot beams are tightly focused and are designed for high elevation mounting to achieve distance, while the flood beams are designed to provide light over a larger area nearer the fixture.
This 150 watt high intensity LED light fixture is an ideal replacement for fragile and hot running 400 watt metal halide lamps. They offer low power requirements, high durability and a versatile mounting system that makes these LED light emitters a superior lighting solution for demanding applications where power and reliability is critical. The heavy duty design and high power of these LED lights make them suitable for a wide array of applications. Each unit is equipped with a back mount trunnion style mounting bracket that allows the light to be attached to flat surfaces and adjusted through 160° of vertical movement. To adjust the unit after mounting, the user simply loosens the set screws located on either side of the unit, moves it into the desired position, then re-tightens the screws. The base of the mounting trunnion is equipped with several machined slots which allow users to utilize existing mounting holes and slide the unit for precise mount positioning.
“Our new 150 watt LED light fixture is perfect for retrofitting light towers from metal halide fixtures to LED,” said Rob Bresnahan with Larsonelectronics.com. “This unit is designed to withstand extreme environments and operating conditions and can withstand rapid temperature changes.”
Larson Electronics specializes in portable industrial lighting equipment, high mast light towers, explosion proof light fixtures, power distribution systems, LED lighting and more. To view their wide range of products, visit them on the web at Larsonelectronics.com or call 1-800-369-6671 for more information. Larson Electronics will be attending the 2016 OTC show in Houston, Texas from May 2nd to May 5th. Visit them at booth 6716 to inquire about their lighting solutions for many industrial applications.
Larson Electronics
www.larsonelectronics.com
Filed Under: TECHNOLOGIES + PRODUCTS, Flanges • supports • mounts • brackets, Lights • signal lamps • indicators
Tagged With: larsonelectronics
Screenshot 2022-05-10 at 12.00.35 PM
FAULHABER: Everything under control
Rockwell Automation offers new online capabilities with industrial automation software
NYE adds Vishay Miniature Position Sensor to product lineup
