17-4PH stainless steel couplings double your torque
By Mike Santora | July 30, 2018
Helical-Standard-Coupling-Attachments-681x1024Helical’s 17-4PH stainless steel flexible couplings (couplers) are suitable when high strength, fatigue resistance and high torsional 17-4PH Stainless Steel H, W and MC Series couplingsstiffness are called for in an application. When compared to both 303 stainless steel and 7075-T6 aluminum, 17-4PH provides twice the torque and can operate up to 600F.
Helical couplings are machined from a solid piece of material, and when the unique HELI-CAL  Flexure is incorporated they can compensate for angular, parallel or skewed misalignment, while providing axial compliance, constant velocity and smooth bearing loads.
The W Series, World Series, and H Series Stainless Steel Series are general purpose couplings are suitable for heavy duty uses such as pumps, lead screws, positioning systems, and processing equipment. The MC Series, Motor Coupling, has higher torque capacity and torsional stiffness with two sets of flexures for increased parallel offset. It is good for pumps, conveyor systems, and industrial processing equipment where absolute reliability is required.
Helical
heli-cal.com
Filed Under: Coupling Tips
Tagged With: helical
Ringfeder — Dynamical torsional stiffness: some couplings need finer tuning
PTDA onProduct Information Exchange
PTDA Transmissions: Lessons from the Pandemic past can shape the future
Shaft collars and couplings feature wide choice of standard bores
