18 watt magnetically mounted handheld LED spotlight from Larson Electronics
By Patrick Curran | December 10, 2015
Larson Electronics has announced the release of a new 18 watt magnetically mounted handheld LED spotlight constructed for industrial use and approved for outdoor environments.
MULBLT-18W-LED-25-industrial-LED-handheld-spotlight-Larson-Electronics
The MULBLT-18W-LED-25 industrial LED handheld spotlight from Larson Electronics is designed to provide high output and a rugged, durable lighting solution for applications where corrosion resistance and waterproof lighting is required. The housing on this unit is constructed of precision machined aluminum for excellent strength and durability, is powder coated for corrosion resistance, and has an IP65 rating for ingress protection against direct exposure to water jets from all directions. It is equipped with an impact resistant polycarbonate lens for increased safety. This powerful LED spotlight produces 1,530 lumens of light, operates on 120 to 277 volts AC, and features an adjustable trunnion mounting bracket with a pistol grip handle and a 100 pound grip magnetic base. This 18 watt industrial LED light is offered in a focused 25° spot beam for distance or 60° flood beam for a diffused wide angle beam and provides a cool white light output with a color temperature of 5000K and a color rendering index of 85 for maximum illumination. The light head on this unit is mounted to a five inch tall handle by an adjustable hinge that allows the head to be adjusted vertically. A 100 pound grip magnet at the base of the handle allows the unit to be mounted to ferrous surfaces, such as steel doors, beams, and railings to allow for hands free operation. The MULBLT-18W-LED-25 operates on current ranging from 120 to 277 volts AC and includes 25’ of power cable terminated in an optional industrial cord cap. This light is ideal for indoor and outdoor applications and industrial operations where wet conditions are commonly encountered.
Larson Electronics
www.larsonelectronics.com
Power Electronic Tips
Filed Under: Power Electronic Tips, Flanges • supports • mounts • brackets
Tagged With: larson
schurter
Compact power entry module has side flange mounting option
ABSOPULSE
Three-phase power supplies with active PFC handle 5-kW industrial applications
Sager Electronics to carry SL Power’s 300-W single-output power supplies
wuerth catalog
Catalog covers certified components for automotive electronics
