The GT21 Series antenna connector utilizes a highly reliable locking mechanism constructed to handle the shock and vibration commonly found in automotive applications. With a lock strength of 98N, the lock emits a clear tactile click when properly mated. A lock confirmation window further prevents incomplete mating.
The rugged GT21 Series connector is available in three termination variations, including a pin-through hole version, an SMT version, and an in-line version. The antenna connector supports single coaxial, 2-port, 3-port, and 4-port cable terminations. The single coaxial version is offered in 4 color-coded keying options.
The GT21 Series is rated for exposure to shock and vibration, sulfur dioxide, high humidity, and thermal shock. The antenna connector has an operating temperature of -40 to +105 degrees C.
Filed Under: Connector Tips
