Check it out: This year’s Motion Control Handbook from Design World separates power-transmission designs (in which raw torque and speed dominate) from motion systems in which positioning and defined profiles dominate. Every component inertia is summed and reflected back to the motor shaft, with tangential drives such as belt and pulley sets reflecting load inertia plus pulley inertia. Required force or torque is quantified across acceleration, constant-run, and deceleration phases, and only then is the motor sized. Four-quadrant servosystem operation demands both root-mean-square and peak current from the drive, and cable runs stay short to limit voltage drop, impedance, and electromagnetic interference or EMI from nearby pulse-width modulated drives.
Another section in the issue clarifies expressions of feedback resolution for absolute encoders — a specification that can cause confusion when engineers are reading datasheets. On multiturn absolute rotary encoders, single-turn or ST resolution and multiturn or MT resolution are both expressed in bits and can even carry the same value … engineers have been warned.
In an article on servomotors, Charan Bhamra of Monolithic Power Systems shares the details of realtime motion control in one parallel-kinematics platform to handle a ball. A Raspberry Pi 5 runs OpenCV at 40 frames per second (isolating the ball by color mask and contour filtering) then passes position to a Cortex M4 microcontroller over serial peripheral interface or SPI. Each motor linearly interpolates between setpoints for jitter-free coordination across the assembly’s limbs.
Another case study in the issue details how software, Stäubli, and Beckhoff technologies form a new CNC solution. The setup pairs ENCY Robot offline programming and simulation with a Beckhoff motion controller issuing standard CNC commands and a Stäubli robot executing the paths. Milling, sanding, and cutting cells involving millions of motion points get commissioned offline … so they’re not taught point by point. That means good parts are made straight away.
Finally, longtime Design World partner and industry expert Terry Auchstetter explains how self-locking gearmotors aren’t brakes. Worm gearing locks only from a dead stop, so inertia keeps an axis turning after power is cut. Complicating matters is how applications such as railroad-crossing gates need the opposite behavior entirely …
Filed Under: DIGITAL ISSUES • DESIGN WORLD
