New PEM® ReelFast® Surface Mount Spring-Loaded Captive Panel Screws Install Precisely and Permanently Where Designed on Printed Circuit Boards
By Hilary Crisan | November 24, 2015
New PEM® ReelFast® surface mount spring-loaded captive panel screws (Type SMTPFLSM™) from PennEngineering® install precisely and permanently where designed on printed circuit boards to provide secure attachment and allow for subsequent access whenever necessary. These all-metal captive screw assemblies mount in one piece on boards using the pick-and-place method and will install in the same manner and at the same time as other surface mount components prior to the automated reflow solder process. The captive screw technology eliminates issues and risks associated with the handling, installing, and potential loosening of standard screws and can be easily actuated with the combination Torx®/slot drive.
PEM Type SMTPFLSNew PEM Surface Mount FastenerM captive panel screws are supplied on tape and reel conforming to industry standards and are compatible with existing SMT automated installation equipment. A polyimide patch affixed to the end of the fastener allows for vacuum pickup. Unlike conventional fasteners, there is no requirement for secondary installation operations, which typically can damage boards and create scrap.   An anti-cross thread feature serves to correct off-angle installations and prevent thread damage during the mounting process.
The fasteners install reliably in boards of any hardness as thin as .063” / 1.6mm. They are available in thread sizes #4-40 through #6-32 and M3 through M3.5 and in multiple screw lengths. Depending on length, the captive screw is designed to retract flush in the up position.
These captive panel screws join a growing portfolio of PEM surface mount fastener solutions engineered to perform a wide range of attachment functions in printed circuit board applications.
Penn Engineering
pemnet.com
Filed Under: Fastening + joining • locks • latches • pins, Screws • nuts • bolts
Tagged With: PennEngineering, pem
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
Omron D41D high-coded non-contact door switch for safeguarding machine tools and robotic cells
