Carlo Gavazzi launches a new and powerful switch-mode power supply in a compact housing. The SPD240C Series features a 150% peak load capability for a full 3 seconds and, at an installed width of only 64mm, this new series saves approximately 25% DIN-rail width compared with our standard 240 watt power supply. This enhanced 240 watt series also includes Active Power Factor Correction which improves the power factor to 0.97 @ 230VAC resulting in increasing the output power capability. Therefore, the SPD240C Series offers more power, using less panel space, thus making it an ideal choice for DC loads.
Additional standard features included with the SPD240C Series compact power supplies are parallel function, universal AC input, enhanced CE certifications, a power “ready” relay output and short circuit protection. Technical features include:
• 150% peak load capability
• Universal AC input 88-264VAC
• Active power factor correction
• Parallel connection
• Compact dimensions
• Power ready relay output
• LED for DC power “low”
• High efficiency to 83%
Carlo Gavazzi
www.GavazziOnline.com
Filed Under: Power Electronic Tips
