Gardner Denver Thomas is pleased to announce the release of its 2755 series variants: 2755BE75, 2755BGHI75, 2755CE60, 2755CGHI60, 2755TE48/40. 2755TGHI52/48, 2755VEF75, 2755VHI75. These oil-less twin WOB-L® piston units are RoHS compliant and are designed for single stage vacuum, two stage vacuum, single stage compressor, or two stage compressor operation. They are designed for a wide array of applications such as Blood or Laboratory Analyzers to Ozone Generators to Packaging Equipment, just to name a few.
The 2755BE75 (115/60/1) is UL approved and provides an open flow of 7.5 cfm (212.4 l/min) and can operate up to 93% of local barometer continuously. It weighs 21.5 lbs. (9.8 kgs) and measures (L x W x H) 10.35” (262.9 mm) x 5.37” (136.4 mm) x 9.32” (236.7mm).
The 2755BGHI75 (230/60/1 & 220-240/50/1) is TUV approved and provides an open flow of 7.5/6.6 cfm (212.4/186.9 l/min) and can operate up to 93% of local barometer continuously. It weighs 22.6 lbs. (10.3 kgs) and measures (L x W x H) 10.35” (262.9 mm) x 5.37” (136.4 mm) x 9.32” (236.7mm).
The 2755CE60 (115/60/1) is UL approved and provides an open flow of 6.5 cfm (184.0 l/min) and can operate up to 15 psi (1.0 bar) or 91% of local barometer continuously. It weighs 21.5 lbs. (9.8 kgs) and measures (L x W x H) 10.35” (262.9 mm) x 5.37” (136.4 mm) x 9.32” (236.7mm).
The 2755CGHI60 (230/60/1 & 220-240/50/1) is TUV approved and provides an open flow of 6.5/5.6 cfm (184.0/158.6 l/min) and can operate up to 91% of local barometer continuously. It weighs 22.6 lbs. (10.3 kgs) and measures (L x W x H) 10.35” (262.9 mm) x 5.37” (136.4 mm) x 9.32” (236.7mm).
The 2755TE48/40 (115/60/1) is UL approved and provides an open flow of 2.6 cfm (73.6 l/min) and can operate up to 160 psi (11.0 bar). It weighs 21.7 lbs. (9.8 kgs) and measures (L x W x H) 10.75” (273.1 mm) x 5.37” (136.4 mm) x 9.32” (236.7mm). Unit comes standard with fan guards and ground wire.
The 2755TGHI52/48 (230/60/1 & 220-240/50/1) is TUV approved and provides an open flow of 2.75/2.30 cfm (77.9/65.1 l/min) and can operate up to 175 psi (12.1 bar) continuously. It weighs 23.0 lbs. (10.4 kgs) and measures (L x W x H) 10.75” (273.1 mm) x 5.37” (136.4 mm) x 9.32” (236.7mm). Unit comes standard with fan guards and ground wire.
The 2755VEF75 (115/60/1 & 110/50/1) is UL approved and provides an open flow of 3.9/3.4 cfm (110.4/96.3 l/min) and can operate up to 98% of local barometer continuously. It weighs 21.5 lbs. (9.8 kgs) and measures (L x W x H) 10.35” (262.9 mm) x 5.37” (136.4 mm) x 9.32” (236.7mm).
The 2755VHI75 (220-240/50/1) is TUV approved and provides an open flow of 3.4 cfm (96.3 l/min) and can operate up to 98% of local barometer continuously. It weighs 22.6 lbs. (10.3 kgs) and measures (L x W x H) 10.35” (262.9 mm) x 5.37” (136.4 mm) x 9.32” (236.7mm).
Units include a cathodic epoxy coated monolithic head, cathodic epoxy coated wetted parts, quality die-cast aluminum components, as well as more robust design features that utilize best practices from other product series. Supplied standard with each unit is a capacitor, capacitor insulator boot, and intake filter.
Please visit gd-thomas’ website to learn more about the new 2755 Series compressor/vacuum pumps.
Gardner Denver THOMAS, is a leader in flow control products for medical, life sciences, and selected other industries – focused on solutions for OEMs. Innovation, global capabilities and a solutions centric approach to our customer’s success is at our core. A global production network with plants in the U.S. (Sheboygan, WI and Monroe, LA), Europe (Memmingen, Germany) and Asia (Wuxi, China) allows fast and flexible reaction to our customer needs.
