28 mm Diameter Ball Screw Compatible with the JIS Standard
By Miles Budimir | July 22, 2010
BURLINGTON, MA — Steinmeyer, Inc. announced a new addition to its line of precision ball screws – a 28 mm diameter screw with 12 mm pitch. Normally our product line is guided by the DIN standard which specifies shaft diameters of 20, 25, 32, 40 mm, etc.
Steinmeyer-ETA+-ball-screw
This new 28 mm diameter product was designed as a size compatible with the JIS standard. The ball screw is supplied with choice of two nut styles: single nut with flange series 1416; or double nut with flange series 1516. The ball nut is normally provided preloaded for zero backlash. The screw shaft is precision ground and offered in accuracy grades T0 to T5. Threaded length, journal details and overall length are per customer specification.
Steinmeyer
www.steinmeyer.com
Filed Under: Factory automation, Ball screws • lead screws, Linear motion • slides, Motion control • motor controls
49503-ACS Motion-CMxa
SDP-SI-040
PACMotion-servos
Going small with 3D printing
