Think Silicon announced today the release and immediate availability of NEMA|p(PICO) the world smallest (0.07mm2 die-area, two times smaller than the competition) and most power efficient (0.05 mW leakage) 2D Graphics Processor Unit (GPU). NEMA|p has a new bottom up architecture, featuring a number of ultra low-power saving methods such as a fixed rate, real time 4bpp/6bpp frame buffer compression/decompression (TSFBc), DAT (Display Aware Technology), CAT (Context Aware Technology) and 25 MHz low frequency SoC support helping to significantly lower power consumption. NEMA|p has been specifically designed for area constrained wearable devices, embedded systems and IoT platforms where power consumption and battery life is crucial and cost efficiency are critical factors while still maintaining vibrant graphics and fluid 2D User Interface (UI) performance.
The Think Silicon exhibit, hosted at the CES Sands Expo Level 1 Hall Booth# 81349, will showcase the NEMA|PICO and NEMA|TINY, the world smallest multi-core 3D GPU, amongst an array of innovations powered by the latest Think Silicon GPU technologies such as “RAPID”, an IoT GUI building tool, as well as a demonstration of the upcoming Vulkan API.
The one-core GPU can be customized for small footprint devices and configured for small displays up from 1.5″ to 6.0″ and XGA (1024×768) resolutions. NEMA|p supports SoCs with a 32-bit MCU (e.g. ARM Cortex-M processors) and core frequencies that reach as low as 25MHz (not limited).
The very small silicon footprint of just 0.07mm2 (150 MHz in 28nm) with ultra-low leakage power of just 0.05mW and memory power consumption of just 0.03mW (in DDR-less systems) features a fully configurable and programmable 2D graphics rendering engine and has innovative composition functionalities.
The NEMA|p is available in Verilog HDL code, supports AMBA interfaces (AHB, AXI), and embeds DMA controllers with command list for minimal CPU overhead. NEMA|p comes with drivers for FreeRTOS, Linux OS, software libraries for graphics APIs such as DirectFB, μGFX, QT, GTK+ and a bare metal C library for OS-less systems.
Think Silicon
The post 2D graphics processor billed as world’s smallest appeared first on Micro Controller Tips.
Filed Under: Microcontroller Tips
